Hi guys
Just interested in hearing what everyone is running and experiencing?
My findings so far.
I ran the default (as shipped) 1440@48fps and it produced approx 16GB/hour via the 4 files.
I'm using a MAC so that then exploded via conversion to mov file format as 80GB, thats 100GB approx per hour,
the battery seems to be just past half, implying 2 hours per charge,
2 hours video footage 32GB MD SDD card,
32 GB source files and 200GB mov to work with, ouch... :S
Thats some large numbers. Just wondering what the quality will be at a lower setting, need to manage the file sizes, running out of HDD space quickly and if the high resolution is not needed then I'd gladly drop lower.
Gonna try 960@30fps today/tomorrow and see what I end with.
G
Edited by awesme
I've changed my Hero3 to the one below 960, 720 or something i think. I don't see the need to record at the max rate.
Hero3 battery lasts about 2h20
And the frames per second?
G
hmm
ok, that is about double the default settings values then.
thanks
G
would have to check but i think 2h20 on 960 was about 16gb and 1h40 on 720 was about 13gb
ahh, ok, the new 720 number makes more sense, the 13GB looked a bit out of place.
Windows, nice you don't have to convert, you can work with the native mp4 format, def helps
G
i'm on Windows. only just got it, so i'm still figuring it all out.
correction 720, 1h40 was just under 8GB
Sorry, bit of a hijack, but does anyone know if and when the battery backpack for the GoPro 3's will be in SA stores?
The 2H battery life (without Wi-Fi on!) is a bit of a buzz kill at the moment ...
Havent tried the gp3 yet, but with the 960 up to the hd hero2, you should get 3 hours minimum bat life, secondly drop the framerates on those to 720, everything else looks shaky and ****. Make sure you have a descent SD card.
I film at 720p X 60FPS. Lets face it... most of the viewing of such vids will be via PC monitor (and often even via youtube/vimeo uplaods) so who needs more than 720p. (I have the original Hero HD, so not as many resolution/FPS options).
It's the frame rate that I look for. A higher frame rate means a more fluid slow motion when editing. I'll take that over a few extra pixels.
  • 4 months later...
