Where can I get Cane Creek Headset Replacement Bearings?
Pointless replacing the whole headset if all I need is the Sealed Cartridge Bearings, actually only really need one as just the bottom one got water contaminated and toasted, I tried repacking it with grease but the bearing surfaces are too pitted and the bearing is all notchy now...
Its a standard 1-1/8" external headset for a 2008 Morewood Shova.
Apparently its called Sealed Cartridge Bearing 1-1/8" 36 x 45 Cane Creek Compatible.
MH-PO3K 35x45 deg
Internal Bearing Diameter is 30.2mm
External Bearing Diameter is 41mm
6.5mm High
Fits standard 1 1/8" Cartridge Bearing Headsets
This here:
http://i.ebayimg.com/t/CANE-CREEK-Cartridge-Bearings-for-s3-s6-s8-headset-PAIR-/00/$(KGrHqMOKiME12+CulP4BNntNMwVCg~~_35.JPG
if you struggle, bearing net or someone similar will have
But its got a slight flange on the inner/outer race, seems quite MTB specific?
You reckon bearing man will keep it?
Edited by Skylark
Pretty sure it's a generic size. Check the skf catalogue online
Either way your LBS "should" stock them or be able to get them.
Nope, it is bicycle-specific.
However, it is a very, very common bicycle part made by 1001 bicycle parts manufacturers. R60 a pop at any bike shop.
For those interested in history, this 36/35 bearing was the first headset cartridge bearing that changed the way bike headsets worked. The patent expired two years ago and suddenly even the Americans think it is a good idea. They (Chris King and company) refused to license it and plowed ahead with a rubbish press-fit system until the patent expired. Now suddenly it is an excellent idea and their headsets use it.
i was in there the other day and they told me they do headset bearings. this was bearing net in silverton
Thank you Johan for putting me straight
