I am planning on replacing the front fork on my jump bike and I see that most jump forks are 20mm through axle. I heard that with some hubs it's possible to covert to the larger axle size. how do I tell if I can do this with my front hub?
I have heard of QR to 20mm converters but not the other way around . If you interested I got a complete 160mm Nixon with a 20mm XT front wheel and 2.6 Kenda tyre .
Have you spoken nicely to your hub and seen how it feels about this conversion?
Alternatively, see if the hub uses sealed cartridge bearings. If it's cup-n-cone then you're outta luck. If it's sealed cartridge the manufacturer may have a kit for it.
Huh?
Depending on the hub you can run it as QR, 15mm, or 20mm. it's not so much a "converting QR to 20mm" as it is simply removing the QR kit and putting the 20mm kit on.
http://lh5.ggpht.com/gram.mullin/SLj4rW-TPtI/AAAAAAAACYw/XgY8xNDAIC8/s800/Picture_hope%20014.jpg
I asked but all i got was: No lo entiendo. comer una hamburguesa con queso......
So i will ask again and use a spanner. thanks for the advice! :)
Hope FTW
