do they make those for xx1 ?looking for a 34t?
hope that is what you call them ,those oval rings,i used to know them as biopace
I thought xx1 bcd of 76 is shared with no other chainring.Can you post a link to the rotor ring that will fit 76 bcd.
Not sure if the OP meant the XX1 Crankset or the XX1 drivetrain (i.e 11-speed cassette and derailleur,chain combo) to be used with a ROTOR Crankset.
You can use most crankset with XX1 in any case. Only "problem" is drppping chain on non-XX1 design chainrings such as FRM or ROTOR that then needs a chaindevice.
Wolf and Sram XX1 does not need a chain-device.
I will be the first to buy a Rotor ring for xx1 if they make one. Have been on q rings foreva. Q ring will give you 2 rings in one due to what happens at your power & weak points. for example, a 30 tooth will cover 28, 30 & 32 xx1 rings all n one.
  • 5 months later...
  • 5 weeks later...
got my X1 q-ring and spider today, doing tankwa this weekend so will report back on how it felt after that.
Please post a pic of the crank!
