Once I lock the suspension and then release it, it will not retract to the suspension mode, anyone got any ideas?
Edited by Sidmouth
Make sure the cable and sleeve enter the 'shifter/lockout' in a perpendicular way, if the cable is skew or bent the cable is probably stuck and can't retract properly. Happened to me as well and I suggest a new cable or sleeve.
Thanks guys
this helps, I had the cable replaced like 4 weeks ago, I think it is happening again,
is it a easy job? my concern is where do I start the setting from when setting to lock-down the cable
OK just checked the cable , it flows nicely, the blue round lock thing is very tight, could this be the problem?
It floes neither back or forth and i have to force it with a tight grip?
