Bike cleaning - Groupset, Cassette etc
Since I have been cycling (since 1998) I have done that and have never had an inch of trouble.
Cool if it works for you go for it, as a rule I don't bring degreaser or pressurized water near my bike, I take components off and put it in degreaser...chain and cassette
Edited by rouxtjie
  • Replies 110
After a dusty MTB ride i just hose the bike down, then wipe clean with cloth and clean between the cassettes with pipe cleaners. leave in the sun for a while while i have a beer. Then lube the chain and shift up and down on the cassette range and put bike away. Then have another beer.
Thanks for all the helpful replies.
The bike is farely new, and being a roadbike the drivetrain is fortunately fairly clean. Its just not shiny and nice like when I bought it.
AFAIK Powasol is not a degreaser. Is this true for Cleen Green (I have CG in my cupboard ATM)? If so then I should be safe to spray onto the drivetrain?
I currently dont have any specialist tools as mentioned, so nothing can come off to clean yet. So it will have to be an on bike brush clean.
I have read to avoid using car wash shampoos on the driver train as it contains wax. I plan to clean the whole bike with Cleen Green (it foams a bit more than Powasol) and dirty bits with Powasol. I will lay a coat of car wax on the frame once I am done as the CG will strip the paint of any protective layer it currently has.
NOOOOO don't do it, cleangreen is an extremely powerful degreaser(just feel how dry your hands are after using it), it will make mince meat of your BB, Headset, any linkages and wheelbearings, sure the bike will shine like a new penny for a while, but it in the long run you are hurting your bike. DONT DO IT
Ok first things, go get the tools I mentioned, you will use them over and over again and they are pretty cheap, some place even sell them as a combo together...chainwhip and lockring remover.
I say again, dont bring degreaser to your bike, take components to the degreaser, you have no control of where the degreaser goes into when you take it to your bike no matter how carefull you are. Degreasers are fantastic products but dont spray your bike with them.
Oh and powasol took grease nicely off my chain and cassette, don't see why it won't do it to grease in bearings so I treat it as cleangreen.
Edited by rouxtjie
Also, have you seen what a strong degreaser does to anodized bits of metal? It would start off as navy blue but come out the other side in full camouflage in an array of shades of blues and greys.
