Help - can you mix and match chainrings on 2x10 ?
Need to replace entire drivetrain on x0 38 24 2x10 - have everything except 24 truvativ chainring , can I use a new shimano xt 24 that I have lying around. In other words this would mean a truvativ 38, shimano 24 chainrings with sram 1090 chain and 1070 casette. Is it worth it to purchase a new 24 truvativ chainring for compatibility ?
if pcd matches ie bolt holes
there are no ramps on inner 24 so should work just fine with shimano
Noticed that 38 said I should use only a truvativ 24b-v1 but then it says you should only use a sram chain and previous chain was a kmc
