Hi Hubber
Just need your help/advice. Last weekend attempt ride over and rear wheel banged over on sidewalk and it went flat. And I'm prepare for exciting amashova and last night did discover there is two small hole. So decide to upside down my bike, take rear wheel out then replace new tube and pump and put back. So did the test it and I'm kinda worried that rear wheel is not very straight when test as it is wobble (watch youtube below) BUT did test ride and no problem.
Actually I need your advice if you feel the same as leave it like this unless if wheel bend or cracked up? Dont want buy new rim which it cost more.
http://www.youtube.com/watch?v=BDJ2vwbGmhM&feature=youtu.be
Guest Latent Blue
Could also be a spoke... one can miss those
you ca take it to your lbs. pleeeeaaaase put oil on that chain I am also doing the amashova and will bring you lube if you dont have. does not look to bad, you can ride the amashova like that
Guest DieBees
Respect for doing the Amashova on that bike! No gears it seems. As youve heard, oil that chain brother.
Keep your cam steady..... then take a side view clip while spinning the wheel where we canobserv the rim...
Other wise take it to a bike shop for quote.Guess it would set you back between R40 to R80(with Stans topup)
Ps...Squirt for the chain and while you at it,grease the Rear Derailure Bearings.
Good Luck...
Thank Guys! Look like I'm broke this moment as long as it can be ridable! :) Sooooo looking forward to amashova!
Oh yes I have lube for chain. Will sort it out tonight.
About your suggestion for oil this chain. Do you know which type of oil I should use on chain?
