Small Frame Stumpjumper 26er to 650b conversion
Da Vinci
Anyone with any feed back on this? Seems the front Fork will manage but not sure if the rear triangle will be big enough. Any input welcome ;)
Link to comment
Share on other sites
  • 5 months later...
Check out 650b Palace (do a google search), they have a list of compatable frames. If my memory serves me correct, your frame is listed there.
Link to comment
Did it on my Camber, it worked perfectly in the front, but the rear wheel had issues in the mud.. Your LBS should have a set of wheels that you can test for clearance.
Tom
Link to comment
also done it with Stumpjumper Comp ...
Use a Ritchey 2.1 or Vee Rubber Mission 2.1 or Maxxis Crossmark 2.1 tyre on the rear for good clearance
Link to comment
Thanks Guys - the small frame doesn't seem to allow for any extra clearance so opted not to. Exploring new bike options in the meanwhile.
Link to comment
