Hi guys,
I would really appreciate your help on this one.
I would like to order a pair of hope brakes m4 with floating rotors (180mm in front and 160mm at the back) with adapter. I am looking be black lever and calipers and red edition for the screws and bolts. (here is and example in green, the order would be M4 in red and red rotors too).
Any advise, I can't seem to find someone who has stock anywhere.
Thanks,
Probably going to need to order that from over the seas.
As far as I know you can only order stealth in black and green apart from the stock color , if you want different colors on the accent parts you need to order the bolts and nuts kit made by hope separately in the color you want.
Guest Omega Man
bikebits.co.za stock the standard stuff but the red bits are aftermarket. You'd have to buy that stuff aftermarket anyway as far as i know.
Doesn't Hope make the aftermarket stuff?
Guest Omega Man
Oh. I didn't know that. Thanks.
Hi guys,
Thanks for your replies, really appreciate. I have tried http://www.chainreactioncycles.com/ but they don't have stock anymore.
@Maxxis you are right, the M4 has been replaced with the E4 and will be available in SA in dec.
I am still waiting for responses from different SA suppliers and will report once I have a confirmed order and especially once I have tried this new toys:-)
Thanks guys,
Guest Omega Man
Hi guys,
Thanks guys,
Bikebits are the online store for the local Hope agents so I'd just get from them.
