Freewheel/Hub body replacement
Griffin
Hi all
I have a ALL TERRA Alloy Sealed Bearing rear hub freewheel (10sp) that needs to be replaced. It off a 2012 GT Zaskar Elite. Anyone know where I can source a replacement (either original or generic) ?
Cant seem to find a serial number or model/make on the freewheel body
Its totally seized...wont turn at all (or at least not without some serious persuasion)
LBS advised that it should be replaced, but would appreciate a 2nd opinion. Sealed cartridge bearings so if they can be replaced it would be cheaper than getting a freewheel body. Guess that mean a special tool to get the bearings out?
I would have a go at getting it apart and replacing the bearings - should be relatively easy, especially if you have a blind hole bearing puller (I do) and can find out how it comes apart - looks like you might need a special tool, but usually once you figure it out they are simple to work on.
Had a look at the Parktools site and from what I can gather the biggest challenge will be removing/replacing the bearing cone. If I can get that out, I should (fingers crossed) be able to replace the sealed bearings and then re-assemble. In this case I guess its lucky that cartridge bearings are used.
that is why is said if you can get the right tool, I had a go at mine, but a few beers and lots of swearing later I decided to get a new one.
ps. that graphic is missing a seal that fits on the outside of the adjustment washers
Also once tried to open and service mine,even dad a go at making a tool to remove the cone,gave up as could not get it open.
The bike shops will most likely tell you its not serviceable.
I found my hub freewheel bodies of that design were packing in so I rebuilt my wheel with hope hubs.
As I said, a lost cause.
The tools, time and new bearings will cost more than a new body.
Moerriedingweg.
Moerriedingweg.
The Oracle has spoken.... :) This is a fact and not an opinion.
It's 100% certain that diy if you have to buy tools to do it will cost more than replacing it.
yip, new one cost be R250.
vs Puller set cost.... R2500.... mmm
Although if it were mine I would strip it and clean and grease the bearings right out the box - brand new....
Off the topic but I saw a blind hole puller set at Adendorff for R675-00. Not great quality but a lot less than the R2500 mine cost. Don't often need it on wheel and hub bearings but it is magic for suspension bearings
