I have the new Shimano XT rear derailer, when I turn the clutch on, I find shifting more difficult, even tighter, not as easy and when the clutch is disengaged, if this normal or could my set up be wrong?
Normal.
Before the clutch thing Shimano was always boasting about their "soft" shifting compared to the competition. The introduction of the clutch negates this claim.
It is wise to deactivate the clutch when not in use since the mechanism put lots of strain on the spring resulting in the clutch becoming less effective over time. Note: it is possible to increase the spring force by removing the cover and using the embedded tool.
I have the same issue--wonder if the old XT was not better never had issue with it.
I dont really see this as an issue.
It is just doing its job, dont like it, switch it off.
:w00t:
