LED light, broken......where to buy LED only
Guest Smimby
Hope the hubbers can help, my 800 Lumens LED light stopped working....after using it as a headlamp.
I checked it with the voltmeter and all seems good up the the LED itself.
Must have cooked it, as the whole unit was HOT when the light went dead
Does anyone know where you can buy / source just the LED part so I can solder it on myself?
Guest Smimby
Thanks very much. Will check out the sites
It depends on the type of LED your light was designed for.
Depending on how old your light is, it could use a Seoul Semi Conductor P7, or if it is newer it might be a Cree XPG or Cree XML.
You can source these LED's from various places online, but if you go local you are a bit more limited. You can try RS components but they mostly only stock the LED chip, which is very difficult to install as it is very small. It is better to source a LED which is already mounted on a star.
You will also need thermal heatsink compound/epoxy in order to fix the star to the body of the light.
You can try Rabtron, but their choices are limited.
I suggest you phone Hannes from Extremelights and ask him for advice, he might have some spares lying around.
Edited by Brian Fantana
Here in Gauteng , there are some " Chine Shops " that specialize in electrical gadgets/equipment. You can buy LEDs over the counter. I am sure you also have some " China Malls " in CT. Try them. The stuff originates from China anyway.
