I've had my keys for ages and my one pedals is giving up the ghost on the pedal bearings. Is this serviceable or should I get new pedals?
I wanted to rebuild my quartz pedals and was told it's cheaper to replace the pedal. Not sure if it will be the same for keo
Pm Mr Look on the hub
As far as I know, No Look pedals are serviceable in respect of replacing bearings. And the replacement kits come with new axle with the bearings pressed on already but they don't include the roller bearings, thats why they so costly.
I have 2 sets and love them but they need regular tlc. I open mine up every few months by removing the axle and keen them out then chuck some bearing grease in the pedal make sure you get it down to the roller bearings at the bottom and then reassemble and you good to go.
If your bearings are toast then sorry, it's new pedals.
