What Oil Volumes for Fox F120 fork?
DemitriN
Looks like an open bath Float RL, no FIT cartridge. I think Fox only installed FIT in 2011 if I remember correctly.
Number 27 on the list would be my guess :)
Thanks for the help. My guess was to put 30ml oil in each of the lowers. But the fox table says to use 160ml on the one side and 30ml on the other.
The table would be correct. That's an open bath damper, so you'll need 160 in the damper leg and 30 in the spring leg, with 5cc of float fluid on top of the air piston.
