Rockshox Recon not compressing
SURFER
I haven't cycle for a while.  When starting again I noticed the the rockshox recon is not compressing while going over bumps. I took it in for service, problem sorted.  Now after about 7 months, the same is starting to happen (shox is not in lock position).
Any advice?
I mentioned it to the guy at LBS, could not find anything specific.  Worked 100% after service.
all shocks/forks require regular service. if I recall correctly the service interval for rockshox is 80 hours
Not sure it is the service interval.  I have Rock shox reba on my bike and ride a lot, no problem.  Both the recon and reba get serviced at same interval.  It seems that not using the recon shox  contributes to the problem.  It was standing idle for long time before my daughter started using it (not regular).
