Front MTB Derailleur... what?
thehoof
Just get it through your LBS.
They are cheap enough and if you don't know what you are looking for at this stage of the fight, you will have a battle fitting the thing.
Top Clamp top pull with a multi clamp size.
Don't be a scrooge .
If the shifter is 14 years old you will need a new one of those too. Also, this is cheaper than replacing 3 chainrings, lighter and significantly quieter.
More expensive than a new derailluer... :whistling:
