Cracked Mavic Hub
CTJ
I went out for a training ride this morning - hill intervals to be exact. When i kicked on the steeper part of the climb my rear wheel suddenly locked up. Long story short the rear wheel was buckling so badly that even after I opened the brake calipers it still touched both sides.
Inspected the wheel when I got home and found the rear hub had cracked - see pic attached. It is a Ksyruim SL 2009 Model.
Wheels were completely re-spoked by Mavic 2 weeks ago.
1) Has anybody seen this before?
2) Is this a known problem with these wheels?
3) What could have caused this to happen?
4) Any chance the respoking of the wheels could have led to this? (Faulty workmanship?)
When you say it was respoked by Mavic did you send it to Dragon sports to do the job or did your LBS do it? Respoking it may have caused it but where it is cracked I don't think it is down to bad workmanship, if it was over tensioned then the flange where the spokes sit would have more likely cracked...this may have been down to a bad bearing change at some point.
Could be Fatigue as it is a 2009 model wheel. Bearing changes in the wheels life could have been a factor in this fatigue as well and the timing of the respoke could be coincidental.
Definitley not a known fault, my thinking is the fatigue route...
just an uneducated opinion and im sure there are more qualified ones on here but Ill bet badly tensioned spokes (a lot more than one because then just the spokes would have failed ) could have caused the hub to fail
if it didn't
and if it was an existing crack that been going for a while
and assuming you didn't damage it in some other way (just saying)
then the crack must have been there and why didn't the wheel builder notice it when he respoked the wheel
if it didn't
Typically if all the spokes are over tensioned then the rim will give way first or else the spokes will give way. Also the wheel will be impossible to get true. All rims and wheels have a point where if you go over the limit they will start to display weird tendencies like not staying true whilst trying to true it.
Probably an existing crack internally caused by a bad bearing change. Aluminum is a material that if there is a stress crack it is not always easy to see - hence why the wheelbuilder did not pick it up. Where that crack has developed is directly behind where the bearing sits...
my uneducated opinion stands corrected
thanks for the education skinny :thumbup:
Bearings are still the original ones - still running as smooth as the day I got them.
Respoked by the guys at Mavic. LBS sent the wheel to them.
  On 7/22/2015 at 2:24 PM, droo said:
Too much power. If you also regularly bend cranks and pedal axles I'd suggest cutting back a bit on the PEDs.
Thanks Man!! If only this was the case........
