24 inch tubeless conversion
andremtb1
I would like to do a tubeless conversion on a 24 inch set of wheels, can anyone help with info on who makes a tubeless tyre in 24 inch, where I can get such tyres.if anyone has done a conversion using wirebead tyres please let me know how. Thanks
Andre
If you try hard enough you can run virtually any tire tubeless including wire bead tyres. With wire bead the ghetto method using a split tube is probably the best method.
