Power meter for Hubbers
Rocket Man
  • Replies 41
Guest colonel
Doesnt the tester have to be able to push out some decent watts? BOB you sure you can handle such a responsibility?
Link to comment
Share on other sites
Ok, we let colonel do the testingBig%20smile
Link to comment
Guest colonel
I aint testing nothing boet unless it has the Name Kendra Wilkinson attached.
Link to comment
Something fun for a Friday. Print the picture below. Cut the page in half between the two sets of railway lines. Turn one page over over and line up the images so that they are on top of each other (printed sides together). Hold the pages up to the light.
If you look closely you will see a darker area and a lighter area because of the way the sleepers line up. If you slide one page over the other by a few millimeters then the dark and light areas move but over a much bigger distance (in the direction of the railway lines) .
What this shows is that a small movement (such as a bend caused by pedaling hard) can be magnified into a very large effect by looking at the "interference pattern" created by stripes if they are laid out in a certain pattern.
This is how we will measure the torque that is converted into a power reading. But instead of optical stripes, we will superimpose magnetic domains encoded onto a plastic disc coated with ferric oxide.20080425_063749_linear_pattern.JPG
Link to comment
Guest colonel
Is this possible with 2 x pix of Kendra? Will her clothes be removed?
Link to comment
ok Rocket-Man, what ever you just said, I'm glad you attached a pictures for some of us...Embarrassed
Link to comment
Guest colonel
Nah' date=' not yet, should be end of may. [/quote']
Are you getting it from Suzuki South?
Link to comment
