3D Printed Bash Ring
Fleming
I had some free time at work today and decided to misappropriate company resources and make a bash ring on our 3D printer.
I know it wont be very strong but I dont plan to use it to protect the chain rings. I want to change from a triple to a double ring setup using the same crank and think the bash ring will make the double setup look more complete.
I will mount it on the bike later and take some more pics.
http://i17.photobucket.com/albums/b69/stuartfleming/IMG_20160422_114704_zps1dncwb5i.jpg
http://i17.photobucket.com/albums/b69/stuartfleming/IMG_20160422_131610_zpsjr2ykfah.jpg
http://i17.photobucket.com/albums/b69/stuartfleming/IMG_20160422_132516_zpswq03xxp1.jpg
Needed a bit of filling to make it fit the crank spigot but overall I am pretty happy.
Posted from a mobile device using Tapatalk.
Cool, but wasn't that moer expensive.
Including electricity to run the printer it was less than R30. Main issue is it took nearly 5 hours to make.
It a mud guard
It can be done but the printed parts are not very flexible. I think it would be easier to cut one from a piece of plastic. The lid of a ice cream container would probably be a good place to start.
Ok cool, just thought it would work but as you say, needs to be flexible
I printed a bash guard for a double ring setup (40/28). It is super strong, I bashed my full weight and momentum on it while I was learning to climb low walls and it barely felt a thing :thumbup:
Printed at 0.2mm layer resolution with rectilinear infill (almost halved print time vs honeycomb) @ 90% infill density
(apologies for the poor lighting in my bedroom)
