Thule ClipON for hatchback
PedalCrazy
Hi all, any advise on which Thule bike rack I should look at for my Toyota Yaris hatch... Will need a 3 bike combo but think that is the standard formation...
Assume the Thule ClipON is the only option (have no tow bar) - anyone know if it would fit a Yaris?
thule have pdf's you can download for each model rack and then look on the pdf for cars that are compatible
Its quite extensive so It should sort you out quick quick
Thanks for the advise... Found a PDF and looks like the correct model is Thule 9103
Have you used a clipon one before?
I could not do that to my car... or sanity while driving. Especially with 3 bikes.
Tow bar mounted ones are worth the extra $ if you going to use it a lot.
