Anthem Rear triangle bearings
lerouc
For pivot bearings, you'll want full complement. A quick search will tell you all the reasons, not going to go into it again.
Enduro are the only manufacturers I know who distribute them locally, you'll need to order through your LBS.
The sizes you're looking for are:
2 x 6902
4 x 6802
2 x 6800
2 x 63800
Shouldnt be a big deal, the only challenge is finding out which bearings you need before you remove them. Normally the Enduro bearings are available - I get mine from Solomons they got lots of sizes in stock. So I would suggest stripping out the old take them to a bike shop that stocks Enduro bearings and get the exact replacement.
If you have an issue then phone Andre at Rush Sports - They the importer
Her some links I found on how to do the job
http://singletrackworld.com/forum/topic/bearing-replacement-giant-trance-x-staightforward-or-nightmare
http://forums.mtbr.com/giant/trance-bearing-replacement-how-242343.html
