Fox Fork replacement seals
TrailWarrior
LBS should have some stock or at least be able to order for you.
I hear you JXV, but when your LBS is more a gift shop than anything else in a small dorpie of a town, one needs to maybe revert to online shopping to avoid frustrations..... lol. I was hoping to find something online but maybe I'll check with the nearest LBS - 200km away ;)
The online stores will also stock/source stuff they don't advertise. Call them. Will help to look up the part numbers on www.ridefox.com beforehand. Navigate to bike and help pages.
Also Droo as suggested. He doesn't advertise as an online store but will supply and courier stuff. Very knowledgable about suspension and helpful.
Contact a hubber named Droo. Im sure he will be able to help you out.
Thanks guys. OP, I have what you need on the shelf. Shout if you don't make a plan with your LBS and I can send you what you need.
Hi Droo,
I have a 26'er Fox 32 (Genesis 2) on an Gary Fisher Himod up front, with a Fox RP 23 at the back. My LBS says he can't get seals etc for those shocks - can you maybe help?
Hi Droo,
I can, I've got stock of both. The fork should be easy enough to do yourself, but the shock requires special tools and is best left to someone who knows what they're doing.
Just doing the air sleeve service on the RP23 won't do much good at all.
