re threading a rear disc mount?
Mongooser
  On 9/14/2016 at 10:12 AM, mongooser said:
bolts screw in and cant pull out but not enough threading to keep them tight
If this is the correct setup:
Then the solution is easy. just buy a new brake mount. The cost about R200 for a new one. Will cost you more to have it fixed.
Take your current mount to your LBS and have them give you one with the same rise to match you disc.
  On 9/14/2016 at 10:11 AM, mongooser said:
morewood shova lt
Shova LT has IS mount. Buy a new brake adapter and you're good to go for less than R 200.
the frame is the one with no threading,ran that same mount on my izumi and worked fine
  On 9/14/2016 at 1:26 PM, Myles Mayhew said:
If you ran the same mount on your Izimu then it's an Adapter, not a mount.
Time for a new adapter.
will have to get on then
