Fox oil volumes
BaGearA
Can anybode help with the oil volumes for a fox talas 29 2013 model. fit cartridge.
The only oil volume chart form fox i can find is for 2002 to 2011 forks.
So i know 30ml  20wt gold in the lowers , 5ml float fluid under the top cap on the shaft
All i'm not exactly sure about is the  10wt that goes under the damper side topcap.
