Need some things to help someone out...
Kalahari Vegmot
So, I built a bike for a guy a few months back from parts I got off the hub-thanks again!
Anyway, the parts were mostly ridden to eternity come, and as such the owner didn't get much riding done before the cassette just goes krrr krrr krrr the whole ride, and the rear shifter se binnegoed is ook nou kas toe...
I've already got a new set of shifters(thanks Eldron!), but still need a cassette/chain combo that doesn't slip, a pair of v-brakes, and a cable and housing kit for the brakes.
If anybody has any of the above lying around, it would be much appreciated
Postage costs will be covered by me
Thanks in advance!
Am sure I have a decent slx cassette & chain 10 speed ...pm me if that helps
That'd be great Pikey, thanks! I'll PM you
If someone has at least a ten speed rear shifter, I can then upgrade the bike to a 3x10 setup.
So please add a ten speed shifter to the wanted list then...
What brand are you using? I've got a set of SLX M670 10 spd shifters in very good nic lying around. Sram X9 10spd rear der.
The bike is currently running a 9-speed SRAM setup.
I'd really appreciate those SLX shifters! Will PM you
