chain slip on heavy gear, Solution?
Gitfo
On what type of frame? Carbon/Steel/Alu?
If there is enough flex in the frame (e.g. steel frame), you might find the chain will slip under big power on the small cog because of a slight twist in the rear triangle.
Iv'e seen this happen once on my steel MTB frame when a 100kg+ chap climbed on the bike and stomped on the pedals in the small cog - chain slipped. I could not repeat this with my weenie power output... just a thought.
