Deore I-spec-B brake lever- without shifter?
scubes
Hi guys I am not sure if this has been discussed before.
My Trance has Deore 615 I-spec-B brakes and shifters-
I am thinking of 1x11 with a new Sram NX shifter or new Slx shifter- both of which would have their own clamp (not i-spec-b).
So can I remove the Deore shifters to go 1x11 and put the new shifters on, and leave the Deore brakes in place? Do I need a special shim if this is possible?
ya of course, I did it with SLX brake shifter combe when I went 1x11
Little fiddle removing the shifters from brakes but takes less than 5 mins and no special tools
So can I remove the Deore shifters to go 1x11 and put the new shifters on, and leave the Deore brakes in place? YES Do I need a special shim if this is possible? NO
