powertap g3 hub cap wrench
le petit nouveau
I am looking for a local bike shop that is able to change the battery of a Powertap G3 power meter hub with the proper hub cap wrench in and around Cape Town please?
i can let you use mine, where are you based? Maybe bring battery & wheel along & you change right there on the spot.
i made one. no ways i'm allowing myself to be held hostage by a 'special tool' that requires spending more money. The tool faces on the cap form a triangle. So using what I had (wood off cuts), i made up a hollow triangle of which the internal faces mate perfectly with the ledges/faces on the cap.
I'm sure there are better ways of doing, but that works with what I had.
