  • Replies 355
16 minutes ago, EddieV said:
Hi, does anyone know whether a 29 x 2.25 tyre (21mm internal rim) would fit the FARR chromoly fork?
Want to use the fork on another frame.
pretty sure it will.
Think this is a 40mm maxxis rambler on it.
can answer you tonight if you wanna know for sure.
I have a specialized fast track 2.1 on and its allready a close fit. 2.25 might not fit to be honest. Its not the width but the tire diameter that is the problem. Not sure how much the diameter will change from 2.1 to 2.25 but when I pick up a little mud and small rocks it touches on 2.1. If youre keen and want do a hack job you can grind away at that steerer sticking out underneath😉
