Brake Adapter for Mattoc Pro 2
AlanD
All,
Fork: Manitou Mattoc Pro 2
Standard mount is 180mm
I want to run a 203mm shimano rotor. Which adapter do i need?
Cannot find a clear answer.
this one , it doesn't really move the caliper back , just more up
fairly cheapish
Nyet. That's for a 160 post to 203 rotor.
OP, you'll need a 160 - 180 post adapter and possibly some thin washers. I've never seen a dedicated 180 - 203 adapter.
Droo is right , I wasnt thinking *facepalm
Can you send me a link or pic to one as I'm not having much luck. There's a hope one that comes up but at £15 they can keep it..lol
I bought a shimano 203mm adapter, pic attached, and it worked perfectly.
That's the standard 160 to 180 adapter, not the 203 but if the Mattoc is already 180 then I guess it makes sense.
It says 203mm on the adapter though..
That's interesting, I didn't know such a thing existed!
That's why I'm so confused as everything pointed to that 160 to 180 adapter. It's definatly a 203mm adapter and fits the 203mm rotor perfectly.
