Unnecessary Garmin Edge Map files
Disco man
Morning
On a Garmin Edge there is map files that takes up quite a bit of space, and I’m sure that they are most probably for other countries.
Looking at South Africa and Namibia witch of these files can I remove from my device to make more space?
By the way it’s a Garmin Edge 820
TopoActive Africa v3.img
Gmapprom.img
D601700A.img
Gmapgc.img
Gmapdem.img
Gmapbmap.img
Gmaptz.img
Regards
Morning
Gmapprom.img
D601700A.img
Gmapgc.img
Gmapdem.img
Gmapbmap.img
Gmaptz.img
Regards
My take on this is as follows:
TopoActive Africa v3.img -  It's a topographic data map, could be usefull if you do MTB'ing.
Gmapprom.img - That is your main road map installed on your GPS, should be usefull if you do road cycling. Used to calculate routes on roads.
D601700A.img - Absolutely no idea what this one is used for.
Gmapgc.img - Map for Geocode data, used to look up POIs.
Gmapdem.img - Elevation data map, could be usefull for both road and MTB.
Gmapbmap.img - Default base map, no real usefull data on it normally.
Gmaptz.img - Timezone map, only usefull if you travel between countries with different time zones.
Thanks all
Garmin support feedback is that I will be doing it at my own risk, but that I could remove the following files:
gmapgc.img - 2.1Gb
gmapprom.img - 3.7Gb
I've removed them and the unit still seems to be 100%. At least I've opened up some capacity on the unit.
