Running 10 SPD derailleur on 11 SPD drivetrain
jmulder01
Will an older long cage Shimano XT M786 Shadow+ 10 derailleur work with 1x11 setup.
Idea is to go 1x11 -> 11-46 cassette
As I see it, the shifter determines the shifting ratio.
So if combined with new XT 11 SPD shifter would this setup be reliable?
  On 10/30/2018 at 9:23 AM, Skinnyone said:
Short answer - no...
The derailleur also has a part to play in the pull ratio - it is not all in the shifter.
This.
The derailleur's "lever arm" length has a direct effect on its function and how far the cage will move per mm that the cable is moved. Increase / decrease that lever arm length, and your RD travel changes.
If they're compatible, it will work. If the pull ratio is the same, then it'll work.
  On 10/30/2018 at 9:23 AM, fanievb said:
According to the above article and video it works - to a degree - there is always going to be a compromise and I have experienced this first hand...the gears are not going to be reliable nor always shift smoothly
Thank you for all the info.
Parts are on their way except chain.
Another question, how many chain links will this 11-46 Cassette with 34T at the front require.
Could you recommend a chain for this conversion?
Chain length is dependent on the bike - a HT will commonly use a slightly shorter chain than a long travel full sus...order a 116link chain and cut to suit - there are a number of different "formulas" for it but I have never had an issue where you go big front and big rear - not going thru the derailleur and then overlap by 2 links...
As far as chain brand goes - get Shimano if you are running the rest Shimano - it will just work better
