Shifter cable ends
RogM
Hi guys
So my Momsen STR 29 frame is stripped, and nearly ready for priming.
But, a couple of questions:
1)   I would like to remove the shifter cable ends from the down tube and chainstay. I see these are brazed on, but I imagine I should rather cut, grind and sand, than remove by heating?
2)   There is no shifter cable end on the seat tube, for the FD.. any advice?
TIA
Cheers
Thanks PeterF
I don't see anything there, where I thought it would have been.
I would rather route it from the top anyway..
Cut using an angle grinder if you're familiar enough with it, or use a hacksaw but keep it straight.. Either way, leave yourself some material so you don't cut into the tube by accident
File, then sand the excess down until she's smooth.
