Thru Axle Parts needed for Hope Pro 2 Evo hubs
PieterJvR
If i decide on new PRO 4 hubs, will my XD freehub off my EVO PRO 2 fit on a PRO 4
No they're not compatible, that's where Hope made the improvement on the Pro 4. The diameter of the ratchet mechanism on Pro 4 is larger
Yep I emailed Hope - they came back and confirmed this - However they also confirmed their boost conversion kit P/No #HUB493 will convert both EVO PRO 2 & EVO PRO 4 to boost, so no need to buy a new hub
Here's a pic of the kit
https://www.rushcycles.co.uk/m50b0s472p5924/HOPE-Hope-Pro-4-and-Pro-2-Evo-Rear-hub-Boost-Conversion-Kit
I have HOPE PRO EVO2 with the 142 X 12 maxle hubs and need to change my frame from the normal width to boost. Is there a conversion kit to convert hubs to boost ? or am i in the market for new boost hubs
Wolftooth's leaves the casette in the same place as it only uses a longer cup on the non drive side and a disc spacer...but the wheel needs to be re-dished and as far as I have read....no new spokes are needed. apparently this way/compromise also gives you the benefits of what a offset rim would give pertaining to dishing.
