Rockshox RT3 - Internal lock-out needle o-ring (help)
SURFER
Where can I find the o-ring for the Lockout sleeve (internal lock-out needle).
The size is:
Thickness: 1mm
The  shox started leaking oil from the grub screw at the lock out.  It seems that the o-ring mentioned above is the problem, but is not part of the o-ring kit.  Struggling to find the o-ring.
Anybody know where I can find this size o-ring?
There are two o'rings that could cause the leak.  The small one you mentioned and a slightly larger one (1.3 by 3.5 mm?). Get them from Droo - he will have the right sizes.
Droo ?
Contact him, but unfortunately need to buy full kit.  Already replaced all the other seals. Will keep on looking
Buy the full kit.  What you don't use now you can use for the next service as you don't need to replace those seals every time you change the oil.  However you do need the pesky little plastic ball for the bleed port which comes with the kit.
Good advice
