Shimano Brakes (i-spec ii) with Sram Shifters.
Grease_Monkey
Hi guys, I'm looking to get hold of an adapter to mount a Sram shifter to my Shimano brakes (M8000 XT, ispec 2) - just the right side, already sorted the left side with an adpater from Lyne for my dropper remote. It's just to tidy up the cockpit a bit.
Wolftooth makes one but EvoBikes is out of stock. Does anyone know where I can get one of these adapters locally? I don't care which brand it is, second hand or new...
They are available on international sites but a bit expensive to ship here, so that won't be an option. Also not keen to go through the effort of trying to find a place that can machine such an adapter, that seems like a bit too much effort for something so small and inconsequential.
I run this setup.
An XO Eagle shifter on an M8000 Shimano lever.   I like clean bars.
It's an adaptor made by a company called TrickStuff.
I run this setup.
What about the clamp I sent you
I have no idea what you're talking about?
Thanks! Where did you buy yours?
I did buy on an overseas trip, but am there often enough if you require one.
Will take some pics later.
I think I should come right. But thanks for the offer, will give you a shout if the others fall through.
