Help needed with internal cable routing
birkettN
Also perhaps try routing it in reverse.  From handle bars to seat post (or vica versa if that is what you are trying).
Also try mounting the frame is different positions in you clamp.   Horizontal, upside down, 45 degrees etc...  Sometimes the change of frame angle is just enough to make the magic happen.
If I remember correctly the internal cable routing on the PYGA is not fully internal, I know it is not on my 110. Internal routine is via a hole at the back above the bb and the housing should be inserted from hole towards seat tube. The rest of the routing is external under the bb and up the underside of the frame. Cable clamps should be the a triple routed type for RD, Brakes and seat post
Life's too short for this BS....especially if you have big hands and no asian sweatshop slaves. External routing for everything except dropper FTW :ph34r:
PS: yey 1000 posts. i can now be trusted as a reputable buyer/seller :P
We all aspire to be reputable  :thumbup: - except my cousin on the oil rig, avoid him by all cost  :whistling:
