Road Bike Stems
Joe Soap
Need some info on road bike stem clamp diameters please.
I have a older De Rosa that needs a longer stem, thinking a 90mm to 100mm will do the job.
Handlebar and steerer diameters are both a tad over 25mm.
Is this a common size or will I struggle to find a 2nd hand stem?
When you say "a tad over 25mm" does that mean 27.2mm?
If so, its a pretty standard size (although larger diameter ones are becoming more common place) and should be easily available
Nope, less than 26mm
Can't remember the exact decimal but it's 25.something mm
They're 1 inch or 25.4mm
Not very common anylonger. Try sjscycles. Co. Uk
I have a 100mm 25.4 stem taken from a.... De Rosa.  ;)
Let me know if you're in the market or interested.
