Hi guys and girls
I am looking for hen's teeth again. My dirt jumper's 2009 Marzocchi Dirt Jumper 2 is in need of a new seal kit.
I know Enduro makes kits for the old school marzocchi's still. Question is if anyone locally stock it though?
Any pointers in the right direction will be appreciated.
Thanx in advance
Edited by CdT85
I had a set of Marzocchi's in the years gone by. The problem you will face is that the agency has changed hands more than once since 2009 meaning older spare parts will be a major challenge.
You may get lucky, I found a set in Zululand Cycles a number of years ago but other than a knowledgeable store with old stock you will be in a little trouble.
Enduro appear to have a single kit for 32mm forks "MARZOCCHI 32 SEAL KIT"
https://www.enduroforkseals.com/products/front-suspension/enduro-classic-fork-seals/FSKMZ32C.html
I would go third party like enduro, hit Google and order online. Then wait and hope!
Edited by BMXER
Thanx bud. Was hoping someone local might stock some in stead of ordering from overseas.
Last few thing i bought was hit and miss on delivery
Try RBC in PE
Also try Droo on the Hub.  If you don't come right I have a set of wipers 32/44. You should be able to get an oil seal from an industrial bearing company.   I also have a combined wiper/seal 32/42/6.5-9.5.  Not sure which your model uses.
I've got a few 32mm large flange sets left, but no small flange ones.
Pretty sure the 09 models were large flange, so P me if you want a set.
This is the hub.  The minute you leave your post to measure something someone else chips in!
Thanx Gents.
Didn't expect so many replies. Much obliged.
Try RBC in PE
Already mailed them this morning about the enduro sets, still waiting for a reply.
Shot Droo. Will strip the fork as soon as I have a gap and send you the deets.
Do you have the dust wipers and the oil seals?
Thanx David. Will get in touch if I get stuck. Got some dust wipers for a previous Marz Dirt Jam fork from you in the past. Didnt think you would still have spares, but good to know.
Edited by CdT85
