So I have the Cotic X in SS setup at the moment. It's fun but at the same time it doesn't get used because of that.
On occasion I would like to have it do duty on the IDT as well as on gravel and some road as well.
Problem is.... my brake levers are just levers. I have an old X9 derailleur and shifter that I would like to use but naturally the bars are too chunky.
I really don't want to spend money on new levers/shifter to make this work.
What are my other options for a 9 speed shifter compatible with SRAM X9?
I don't have SRAM so can't give a specific answer but when I was looking to fit 9/10 speed shimano to (ironically) my X, Google had lots of articles on compatability of components. Worth a search?
Can be done... Did exactly that on one of my builds. You just need to open the clamp a bit and you will need a slightly longer clamp bolt to secure.
Pictures here: https://cdn.bikehub.co.za/uploads/monthly_10_2020/post-7810-0-69556100-1601633684.jpg
Alternatively you could use a barend shifter like this
20190622_121406_6049ae7ad0199d267f755852
