 Stage 4 Cholet TT:
Duration:  39:10:00
Work:      862 kJ
TSS:       57.4 (intensity factor 0.938)
Norm Power:375
VI:        1.02
Distance:  18.483 mi
MinMaxAvg
Power:       0903367watts
Heart Rate:  104171160bpm
Cadence:     30146102rpm
Speed:       13.246.928.3mph
Headwind section:
Duration:  24:28:00
Work:      567 kJ
TSS:       38.5 (intensity factor 0.972)
Norm Power:389
VI:        1.01
Distance:  10.493 mi
MinMaxAvg
Power:       0903386watts
Heart Rate:  104171162bpm
Cadence:     64129101rpm
Speed:       14.241.325.7mph
tailwind section to finish:
Duration:  13:12
Work:      267 kJ
TSS:       16.9 (intensity factor 0.876)
Norm Power:350
VI:        1.04
Distance:  7.29 mi
MinMaxAvg
Power:       0704337watts
Heart Rate:  136169157bpm
Cadence:     30146104rpm
Speed:       13.246.933.1mph
75kgTongue
I asked the same question!
...but why is his Intensity factor less than one for a 39min TT?  Slacker!
Good point!
David Millar averaged 400w for a 36 min TT by way of comparison (www.saris.com)
75kgTongue
He he, you try riding a 39min TT at around IF = 1 when your TSB is -64 (I estimate).
Especially when you aren't a GC contender.
Bruce if that norm power is the correct data then he must be less than 75kg??
Maybe more like 65kg??
Why do you say that?  NP is not related to weight in any way.
If he's weight is 75kg he's power to weight for the TT would be 5watts per kg.Would that not be very low for a euro pro??
He's ftp would also be 5.33 watts per kg.
To be able to do that after 3 days of riding 5 hours at over 300w, that is the difference.
The numbers do seem to be quite achievable, what amazes me is their ability to produce them day after day for such long periods of time.
Main GC contenders are in the vacinity of 6w/kg.
When Landis won, he was 68kg and FTP 400w - so 5.88w/kg.
O ok!!I would have thought that Power to weight for a Tour rider would be higher than 5.33.
Don't we have a lot of pro's in this country at that figure?
I doubt if he was riding at 100%. He is a domestique, he was probably saving his legs for later, most of the sprinters other than Hunter were.
I doubt if he was riding at 100%. He is a domestique' date=' he was probably saving his legs for later, most of the sprinters other than Hunter were.
Agreed, only GC contenders and TT specialists that are looking for a stage win would go flat out.
5.33w/kg is quite a surprise, there are certainly people in S.A. with those kinds of numbers - even Andrew Mclean is up there with those numbers.
However, the sheer fitness of these guys is what really amazes me.
From what I've read it appears that power outputs are starting to drop, the implication being that the sport is becoming cleaner. If so, the riders could be riding more conseravtively, knowing that there is no loner a 'magic bullet' at the end of each day's racing!
From what I've read it appears that power outputs are starting to drop' date=' the implication being that the sport is becoming cleaner. If so, the riders could be riding more conseravtively, knowing that there is no loner a 'magic bullet' at the end of each day's racing![/quote']
Damn, just when I'm too old...
