Logic tells me it can be done, but sometimes cycling is not always logical.
Can one mix any brand of caliper with any brand of lever?
I understand that you cannot mix DOT and mineral oil brakes, but other than that, they should be compatible.
Yes if both use the same oil and you can connect them properly iit'll work
BUT , the lever will still have to displace a similar amount of oil as the original
Shimano levers with Magura calipers are a common case of these types of work arounds
