1 hour ago, Allrounder said:
Out of interest, what would a ball park figure be to upgrade a 3x9 system to a 1x12? I get prices for SRAM and Shimano, but nothing on Sunruace?
Sunrace only provide the cassette.
So you stil need the trigger shifter, derailure, cable, chain, as well as a narrow wide front ring.
Last time I did such an upgrade an "upgrade kit" worked out cheaper than buying the components.
QUESTION : do you want to do a budget upgrade, i.e. slip a 12 speed cassette onto the standard old freebody ?
Rather do a 1x11 ugrade.  You still have the same 11 tooth as the small gear.  A 1x11 system is much more reliable than a cheap 1x12.
Thanks for the info. Im so far behind on tech being of the bike for a couple of yaers.
Speak to Janos at Evobikes.
Also keep an eye on CWC / CL (Chris Wilemse and Cycle Lab), they often have nice specials.
PS - the more expensive 1x12 setups run a different freebody, "micro spline" for Shimano, this allows them to go down to 10 teeth.  Now the upgrade hurts your wallet ...
