14 hours ago, thebob said:
Order the lever from your LBS
Supplier doesn't have the blade in stock (or indeed even the SKU listed on their system - just checked) so currently not an option...
You can buy a complete lever assembly, but that's a bit silly for a little knob that's broken off.
OP - Get your LBS to contact the supplier and see what can be done, the lever blade is available from SRAM as a spare part for much less money than the entire assembly.
