  • Replies 53
Toss them.
Rotors cost about the same as 2 sets of pads (or thereabouts). You will never get those rotors 100% and just damage your pads.
Try pick up some used ones here on the hub. Someone will have some spares lying around.
I want to know what you did to bend it?
Apparently you should use a heavy pot on a stove. Put the rotor between the pot and plate and heat it up and then just let it cool down.
Wasn't there something about putting them on the stove, then putting a pot full of water on top and bringing the water to a boil?
I faintly remember something like that... curse this beer-riddled memory!
Wasn't there something about putting them on the stove' date=' then putting a pot full of water on top and bringing the water to a boil?
Sounds like the start of potato salad or something... Maybe some soup?
I bent both rotors doing the Entabeni Big5 race. Not sure how I bent them, might have been rocks bouncing up. Gonna put the hammer away and try the stove trick. Thanks a million for good advice.
"If you can't fix it with a hammer then it is an electrical problem!"
I bent both rotors doing the Entabeni Big5 race. Not sure how I bent them' date=' might have been rocks bouncing up. Gonna put the hammer away and try the stove trick. Thanks a million for good advice.
Cool, when will the soup be ready?
