Ok about a year ago my Dad and i bought 2 sets of Neuvation wheels from a cycle shop in Cape Town. So anyway, now the rims have started small cracks. You know where the spoke goes into the rim? Ja there... Its bad! A friend showed me a set of Neuvation wheels that he WAS racing on which have massive cracks in the rims...! He has replaced the rims 3-4 times!!!!
So now what we are thinking of doing is just replacing the rims and building up new wheels with the old spokes and hubs. Is that a good idea? What rims could we use? Rear wheel has 20 spoke holes and the front wheel has 16 spoke holes.
Any advice?
These are the wheels...
Turtlek, you were right mate... smiley2.gif Speedi2008-10-07 10:02:53
  • Replies 50
The answer is not as simple as yes or no.
You can re-use a hub if you manage to duplicate the original lacing so that the spokes all point the same way as they did before the rebuild.
You cannot re-use spokes unless you're replacing the rim with exactly the same rim and tape the two rims together before transferring the spokes to their new rim holes. If you move the position of the spokes, they will start to break very shortly.
However, a new rim will have a different Effective Rim Diameter (ERD) and will not fit on those spokes, making them either too long or too short. It is very seldom that you'll find a rim with the same ERD as what you require.
 Choices in 20 and 16-hole rims are limited.
Therefore, you're between a rock and a hard place: re-build the wheel using the rubbish rims or, trashing the wheel and getting something decent.
  Quote
You cannot re-use spokes unless you're replacing the rim with exactly the same rim and tape the two rims together before transferring the spokes to their new rim holes. If you move the position of the spokes' date=' they will start to break very shortly.
?Choices in 20 and 16-hole rims are limited.
Ok so in other words the spokes are useless if you are not going to be using the exact same rim?
  Quote
Yup. I'd cut my losses, make bathroom mirror from those fancy wheels and invest in a pair of standard wheels with old fashioned Shimano hubs, box section rims and real-world spokes.
  Quote
  Quote
Yup. I'd cut my losses' date=' make bathroom mirror from those fancy wheels and invest in a pair of standard wheels with old fashioned Shimano hubs, box section rims and real-world spokes.
Ok, so on a rough guess how much would it cost for decent rims and good spokes?
  Quote
And the lesson were learnt here today ... don't buy neuvations.
Yes indeed! I can advise anyone that reads this post:
Do not buy a set of Neuvation wheels! Tell all your friends and family! smiley36.gif Speedi2008-10-09 12:39:06
  Quote
so this all teaches us...don't buy neuvation....buy eastonLOL
Yes iv heard they are really good... And also look good! A Scott with Easton wheels... smiley4.gif
