Did 2 conversions last night on a Kenda Karma (used, folding) and Tioga Yellow Kirin Magnum 66 (also used and wire bead).
This morning the Kenda had lost some air(might be due to the tyres prior use), Tioga still hard.
I used (as a test) Raleigh ProSeal as a sealant. at R24 for 500ml at PNP you can't go wrong.
TNOSE_E2008-11-07 01:40:40
  • Replies 74
The wheels are not mine, but will ask the guy to give some feedback. I have used the green slim but find it too thick. The Proseal seems to work just as good as Joe's.
We will see after 94.7,C2C and Babbas.
TNOSE_E2008-11-07 02:03:42
So total cost here.
Tube R40
Nylon tape R4 (Can do more than 6Rims R24)
Proseal R12 (Use only half for a wheel R24)
Total conversion R45 per wheel
TNOSE_E2008-11-07 04:20:35
I did a conversion this weekend with 20 inch tubes and sealent. Worked like a charm (easier than I thought) but around the edge of the rims some of the sealent is bubbling out very slowly and I seem to be loosing pressure. Any recommendations? Will it stop?
  Quote
Did you thrash it round left right up down sideways a few times? It will seal with some time but keep a nice high pressure for now to allow the tyres bead to seat against the new tube liner. Also give the wheel a spin every time you pass.
TNOSE_E2008-11-10 00:33:21
