NCR - Some carbon fibre questions
Where can I buy carbon fibre tubing and sheets? I need a flat sheet approx 400mm x 400mm and 2 - 3 mm thick. I need a tube 10 - 15 dia and a small tube 5mm dia.
Further, can carbon fibre be bent by heating and folding..... same as you would bend plastic or perspex.
I assume Carbon fibre can be drilled, cut and sanded. I also assume that protective gear like a facemask needs to be worn.
Any advice or replies will be appreciated.
You guys in Danville get up to some very wierd stuffWink
Bilxem, moer, donder en opf@k flits nou voor my oe verby. Slaat met 'n ge-chrome-de kempekkernoglia ketting raak ook nou gepas!!!!!!!!
Bilxem' date=' moer, donder en opf@k flits nou voor my oe verby. Slaat met 'n ge-chrome-de kempekkernoglia ketting raak ook nou gepas!!!!!!!!
HEHEHEHEHEHEHEHEHEHEHELOLLOLLOLLOLLOLLOLLOL
Krap net so n' bietjie waar ek nie moet nie maar ek laaaaaaaik die BULLE glad nie.
I have a contact for you if you are interested.
Hi Paul, please PM me with the details. But before you do that, can CF be manipulated by bending and folding????? If it cannot I will have to use aluminium.
Hi Paul' date=' please PM me with the details. But before you do that, can CF be manipulated by bending and folding????? If it cannot I will have to use aluminium.
No it can't. Use ali. Heating epoxy (the resin used to harden carbon) completely destroys it's properties.
Thanx Mark, Paul please PM me the contact details (email address preferred as it is a schlepp to phone from Angola) I still need to buy the CF tubing. I want to do some modifications on my RC Helicopter.
Wat maak jy oom H? Daai stukkie is te klein vir 'n bonnet vir jou bakkie en daai pype gaan smelt as jy dit vir 'n exchaust gebruik.
Die Tandem kan nie meer verder ge-bling word nie. Anycase ons twee oues sal nooit die Tandem tot sy volle kapasiteit kan benut nie.
Ek speel deesdae met RC Helikopters. Ek wil so bietjie CF bling op die kleintjie sit. Ek het juis vandag aluminium parte bestel uit Windhoek uit om hom beter te laat perform. Ek vlieg die ou dingetjie al te ougat!!!!!
Ek het ook die' vir my bestel!!!!!!!
http://www.jixhobbies.co.za/images/index.2.jpg
Just another question. Will I not need a Autoclave and vacuum pump if I make my own CF thingie. Can you just use it like Glass Fibre??????
Wat kos so aeroplane deesdae Oom H? Dit lyk na 'n jol!
